Designed for positioning or as an easy pick-and-place system, the slide is available in eight sizes from 4 to 20-mm diameter and strokes to 200 mm. An end-position interlock and an optional clamping unit keep loads from lowering onto workpiece carriers in an air-supply failure and provides protection in emergency stops.
Three different end-stop systems (shock-absorber, cushioned metal stops or polymer stops) are available.
Festo Corp.
395 Moreland Rd., Box 18023
Hauppauge, NY 11788
(631) 435-0800
festo.com/us/dgsl
Jan. 10, 2025
Jan. 10, 2025
