The TEX Series of position sensors sports stroke lengths up to 300 mm with ±0.05% linearity and 0.01-mm resolution. Pivot heads provide a large angle of free movement to eliminate side-load errors. The unit withstands adverse environment conditions such as humidity, oil, and dust, and is rated to IP66 protection. The TEX comes in multiple mounting options that include fixing clamps for center bushing or bolt-through flange plates.
Novotechnik U.S. Inc., 155 Northboro Rd., Southborough, MA 01722,
(508) 485-2244, novotechnik.com
Dec. 23, 2024
Dec. 23, 2024
