The couplings can incorporate keyways, straight-through, and stepped bores mixing inch-metric dimensions, remachinable bores, and low-profile or heavy-wall designs. The products are easy to install and adjust, have nonmarring bores, and high-torsional holding power. Torque capacity of the 2.5-in. coupling is 8,000 lb-ft. For applications requiring higher torque, the same-size Power-Ring coupling offers 32,000 lb-ft.
Stafford Mfg. Corp.
Box 277
North Reading, PA 01864
(800) 695-5551
staffordmfg.com
Safety Products Overview
Dec. 20, 2024
