The package is optimized for KS shelf-mounted injection-molding robots. It includes an SPI interface between the IMM and robot, a Festo DeviceNet Valve stack with vacuum generators, and complete energy supply and pneumatic tubing from the robot base to the sixth axis faceplate. End-of-arm tooling can be connected with no additional accessories. Six-axis robots have 3 to 500-kg payloads and 635 to 3,700-mm reaches, all controlled from a common PC-based platform.
Kuka Robotics Corp. USA, 2250 Key Dr., Clinton Township, MI 48036, (866) 873-5852, kuka.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
