Optional rivet-holding jaws assist in accurate fastener positioning prior to assembly. Weighing just 23 lb, the Model 216 packs up to 2 tons of rivet-setting force — transmitted via the same toggle mechanism used in larger automatic riveters. Rivet capacity is 0.187 diameter X 1.0-in.long semitubular mild steel. Machine dimensions are 4-in. wide, 8-in. long, and 14-in. high, with 1.25-in. stroke and 6-in. throat depth. Standard tooling includes a rollset and driver. Custom arm lengths and tooling options are available.
Milford Fastening Systems, The Orbitform Group, 1600 Executive Dr., Jackson, MI 49203, (800) 816-9661, orbitform.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
