Hardened Washers Combine Standards
June 7, 2006
Heavy-duty USAE washers combine attributes of USS standard and SAE washers.
The outside diameter conforms to USS standards and is 36% larger than standard hardened washers for greater holding power. A smaller inside diameter conforms to SAE standards, which gives a more precise fit on bolts and nuts.
USAE washers are up to 37% thicker than standard offerings. They are mild steel, case hardened to 60 HRc, with a black-oxide finish. Bolt size is stamped on each washer for easy identification. Washers come in bolt sizes 0.25 to 1 in. and held to tolerances of M0.010 in. All are made in the USA.
Jergens Inc., 15700 S. Waterloo Rd., Cleveland, OH 44110, (216) 486-5540, jergensinc.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
