The device mounts directly to the control cabinet side and provides up to four Micro (M12) D-Coded connections (outside) to four RJ45 connections (inside).
Ethernet panel-mount receptacles directly mount to the control panel for 1 Micro (M12) D-Coded connection (outside) to 1 RJ45 connection (inside) and Panel-Mount Receptacle, RJ45 Jack to RJ45 Jack with Bayonet Lock on exterior.
Lumberg Automation USA
14121 Justice Rd.
Midlothian, VA 23113
(804) 379-2010
lumberg-automationusa.com
