Terminal Blocks
Oct. 12, 2006
The Allen-Bradley IEC terminal block line now includes feed-through blocks and accepts up to 500 MCM wire so users can operate higher-current applications safely.
Safety is increased with a fingersafe feature and larger wire sizes. Benefits include more secure connections, faster installations, and improved panel appearance for highvolume, feed-through terminal blocks with interlinked terminal block markers. The markers snap into the blocks and interlink to markers in adjacent blocks. Up to three center-jumpers, each with a distinct color, can be installed for moreefficient maintenance and operation. Expanded marker options and colored wiring and cases increase panel organization and circuit traceability in wiring panels.
Rockwell Automation, Response Center, 10701 Hampshire Ave. S, Bloomington, MN 55438, (800) 223-5354, rockwellautomation.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
