Power PCB Relays
April 13, 2006
The G5LB and G5LB-25 Series power PCB relays require 20% less board space and are 20% shorter than conventional sugar-cube relays.
The devices unique geometry lets them switch 10 A at 120/250 Vac and 8 A at 30 Vdc, as well as switch digital signals. Power consumption is 360 mW. The fully sealed relays are available in SPDT and SPST contact configurations. The G5LB operates at 40 to 85°C with an electrical life of 100,000 operations, and the G5LB-25 operates at 40 to 105°C with a Class F insulation system and an electrical life of 200,000 operations.
Omron Electronic Components, 55 Commerce Dr., Schaumburg, IL 60173, (847) 882-2033, www.components.omron.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
