The corrosion-resistant spool-valve motors distribute fluid in and out of a Gerotor (H Series) or Geroler (S and T Series) orbit gearset through valve slots machined into the output shaft.
Benefits include high efficiency, high power density, infinite bearing life at rated loads, extended shaft seal life, and smooth operation.
Eaton Hydraulics Operations
14615 Lone Oak Rd.
Eden Prairie, MN 55344
(888) 258-0222
hydraulics.eaton.com
