Multiplatform Backplane Chassis
Sept. 27, 2007
The EZ-Test multiplatform chassis, available in 3U and 6U models, is designed for test and development environments, such as in embedded military systems, R&D, and test equipment.
The chassis supports VME, VME64X, VXS, VPX, PXI, or CompactPCI backplanes. The power supply has 115 to 240-Vac nominal input, 90 to 264-Vac operation input, and 250 to 600-W output. The power supply sits in the rear-enclosed bottom or optional front plugin. There is a 150-cfm fan under the front PCB area for cooling. Additional space has been allotted for two additional 60-mm, 20-cfm fans. The unit’s open-frame design eliminates the use of expensive extender boards during electrical-circuitry testing. The platform’s all-aluminum construction includes a 901 Series extruded guide-deck assembly with flameproof protection. Front rails featuring stainless-steel inject/eject plates assure long insertion/extraction life.
Triple E Corp., 60 Foot of Crosby St., Lowell, MA 01852, (978) 453-0600, TripleEase.com
Jan. 17, 2025
Jan. 17, 2025
Jan. 17, 2025
Jan. 10, 2025
