New Product: Linear actuators
May 8, 2008
The GSX30, 40, 50, and 60 Model and I Series 30 and 40 Model electromechanical linear actuators now feature an integral force-measuring option.
A load cell embedded within the actuator obtains electronic data relating to the force being applied by the actuator. A strain-gage load sensor is mounted inside the actuator’s case. The actuator has ±1% linearity, ±0.5% repeatability and hysteresis in compression, optionally tension, and static or dynamic loads. The option comes with a separate connector for interfacing the internal load sensor to an external strain-gage conditioner/amplifier required to excite the strain-gage sensor. Strain-gage conditioners provide either a 0- to-10 V or 4-to-20-mA output for monitoring the output signal.
Exlar Corp., 1470 Lake Dr. W, Chanhassen, MN 55317, (952) 368-3434, exlar.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
