The cylinders feature self-aligning graphite pistons fitted to Pyrex-lined stainless steel cylinders. They serve in –85 to 302°F applications that call for a smooth range of motion at pneumatic pressures down to 0.2 psi. The cylinders need no oil or seals, and all exposed surfaces are stainless steel or nickel.
Isotech Inc.,
777 Schwab Rd., Suite T, Hatfield, PA 19440,
(800) 314-3332,
isotechinc.com
