The combination unit operates from regulated 24 Vdc and comes with or without an integral gearbox. Both parallel and in-line gearboxes are offered with outputs ranging from 1 to 2,500 rpm. Speed control and direction is via a ±5-Vdc input signal. Custom units include the 24-Vdc brushless motor, an open-loop voltage-mode PWM controller, direction input, dynamic braking, and a built-in 256 PPR two-channel encoder.
Bodine Electric Co.
2500 W. Bradley Place
Chicago, IL 60618
(773) 478-3515
bodine-electric.com
Dec. 12, 2024
Dec. 12, 2024
Dec. 12, 2024
