New Products: Frequency Inverter
Aug. 7, 2008
The Movitrac LTE B drive simplifies control of asynchronous motors.
The new drive, with dynamic braking, better low-speed motor control and embedded communications, comes in three sizes with either a standard IP20 or rugged IP55/NEMA 12k housing for demanding environment.
The drive’s power range is 15 hp for NEMA-1 units and 10 hp for NEMA-12. New control algorithms improve motor-control performance at low speeds.
Users control operation and diagnostics via a remote keypad. A copy stick copies parameters from one drive to another for fast machine setup. An onboard S-bus, compatible with gateway fieldbus devices for DeviceNet, Profibus, EtherNet/ IP, and Profinet, lets users add capabilities as needed.
SEW-Eurodrive Inc
125 Old Spartanburg Highway, Box 518
Lyman, SC 29365
(864) 439-7537
seweurodrive.com
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
Jan. 10, 2025
