Heat-Activated Adhesives
June 22, 2006
Double Sided Heat Activate Series (HA) of tapes combines foam, Mylar, and tissue carriers with pressure-sensitive acrylic adhesive on the close side, and heat-activated adhesive on the open side.
The heat-activated adhesive provides ultrahigh bond strengths to lowsurface-energy (LSE) materials. There are many heat-activation methods, but the best for this Series is hot air blown directly onto the surface. As the adhesive cools, the resulting molecular exchange forms a durable, long-lasting bond to most rubbers, EPDMs, PUs, and PVC-based LSE plastics. Likewise, the acrylic PSA on its close side provides high adhesion and shear strength to most finished surfaces. The Series also perform well on conformability-to-bonding surfaces and resists solvents, chemicals, UV, and heat.
V. Himark (USA) Inc., 11911 Clark St., Unit #E, Arcadia, CA 91006, (877) 844-6275, vhmarkusa.com
