High-Gloss Thermoformable Sheets
June 22, 2006
Senosan CM61SolarNew-EG sheets have a thermally stable, impact-resistant PC/ABS-blend layer coextruded with a top layer of high-gloss acrylic.
The sheets easily thermoform and a protective film can be left on the sheets throughout the production process to prevent scratches. The PC/ABS-blend needs no predrying before forming because it comes packed and sealed in moistureproof aluminum packaging. CM61SolarNew-EG sheets can be color matched in many solid and metallic colors.
Senoplast USA Inc., Suite 111, 75 Executive Dr., Aurora, IL 60504, (877) 736-6872, senoplast.com
