Product Spotlight: Anaerobic Adhesives
June 19, 2008
Rite-Lok anaerobic adhesives are designed for threadlocking, threadsealing, pipe and hydraulic joint sealing, retaining of cylindrical parts, and gasketing.
The adhesives cure to tough plastic in the absence of oxygen and in the presence of metal. They come in a wide range of viscosities, breaks and prevailing strengths.
Rite-Lok cyanoacrylate (instant) adhesives come in liquid and gel formulations and cure in seconds to bond many substrates. The line includes low bloom/low odor, temperature resistant, surface insensitive, and rubber-toughened and plasticized formulations.
Two-step Rite-Lok structural acrylic adhesives bond a wide variety of substrate combinations, including metalto- stone, plastic-to-metal, metal-tometal, and plastic-to-plastic. These adhesives eliminate the need for epoxies, thus saving surface-preparation time.
3M Industrial Adhesives and Tapes Div.
3M Center
Building 220-5E-06
St. Paul, MN 55144
(800) 362-3550
3M.com/bonding
Granite Motion Systems for Precision Automation
Feb. 7, 2025
PI Granite Based Motion Systems. We provide custom Engineered Multi-Axis Precision Automation Systems, built to your specifications– quick turnaround
Feb. 7, 2025
Flexible Multi-axis Granite Motion System for System Integrators and Machine Builders
Feb. 7, 2025
PI’s X-417 multi-axis positioning system / multi-axis stage is a granite motion system for high speed, high precision automation. Preconfigured with a granite base and EtherCat...
Laser Beam Steering Solutions, Fast Steering Mirrors
Feb. 7, 2025
Fast Laser Beam Steering Mirror (FSM) | Piezo Steering Mirrors | Voice Coil | Tip/Tilt Mirrors, Frictionless Flexures, High-Speed Piezoelectric Drives
