Valve Lubricant And Sealant
Sept. 1, 2005
The 111 valve lubricant and sealant is a heavyconsistency, dimethyl-silicone compound that resists organic and inorganic chemicals.
The product can be used as a lubricant for rubber and plastic O-rings, water softener and faucet valves, valve stems for potable water, aircraft-vacuum systems, and electronic and ignition systems. Sealant uses include vacuum and pressure systems, equipment subject to washing and harsh environments, electrical-service entrances, and underground connections. The lubricant and sealant maintains a serviceable consistency from approximately 70 to 400°F.
Molykote, Dow Corning, Box 994, Midland, MI 48686, (989) 496-7881, molykote.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
