Miniature Valves
Jan. 12, 2006
Selector valves can be used as quiet replacements for solenoid valves in packaging machinery, medical equipment, industrial robots, and other applications.
The standard version lets a single input be switched between two, up to six, output ports. An optional version with built-in check valves lets two, up to six, input ports be switched to a single output port. This eliminates multiple pressure gauges. Both versions come with detents for manual operation with a knob, or without them, for automatic operation with servos or stepper motors. The outside diameter of the valve head is about 1 in.
Beswick Engineering Co. Inc., 284 Ocean Rd., Greenland, NH 03840, (603) 433-1188, beswick.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
