UV-Curing Resin Speeds Assembly
July 13, 2006
Light-Pad 4-20645, a onecomponent resin, bonds protective cushioning pads to most surfaces in seconds under 365-nm UV light.
The resin is solvent-free, can be dispensed by machine, cures in-line directly on the part, and resists moisture and thermal cycling.
Dymax Corp., 51 Greenwoods Rd., Torrington, CT 06790, (860) 482-1010, dymax.com
