Brass Fittings
June 7, 2007
Thermobarb barbed brass fittings work with flexible tubing and reinforced hose such as PVC, polyurethane, silicone, thermoplastic rubber, Viton, and Hytrel.
The heavy-duty fittings have a temperature range of –40 to 180°F in sizes from 0.125 to 1.0 in. Newloc push-to-connect fittings work with semi-rigid and rigid nylon, polyethylene, and polypropylene tubing. The fittings disconnect by pushing a collet and pulling out the tubing. Newloc fittings handle full vacuum and temperatures from –10 to 200°F in sizes from 0.125 to 0.50 in. Both styles include male and female adapters, elbows, Ts and Ys, connectors, reducers, swivels, and bulkhead options. Applications include general industrial use, pneumatic control, robots, and instrumentation.
NewAge Industries, 145 James Way, Southampton, PA 18966, (800) 506-3924, newageindustries.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
