Mechanical Product: Gear Reducers
April 10, 2008
Eleven product lines covering in-line gear reducers, right-angle gear reducers, and linear-mount products are covered in a 72-page catalog.
Four new product lines include the SPL Series of shaft output in-line planetary gearboxes, the FP Series of shaftless in-line planetary gearboxes, the SSP Series of washdown servo in-line gearboxes for sanitary applications, and the Dyna Lite Series right-angle gearbox.
Also covered are in-line and right-angle gearboxes that simplify mounting to a linear ball screw or belt module. The products’ hollow output eliminates the need for additional couplxings or adapters. Another mounting solution is the Linear Slide Kit that simplifies mounting linear slides to motors and gearboxes.
GAM
901 E. Business Center Dr.
Mount Prospect, IL 60056
(847) 649-2500
gamweb.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
