Battery Ignition Switch
April 27, 2006
The 95614 compact battery ignition switch with keys has two positions: off and ignition.
For safety, the key is removable only in the off position. The heavy-duty switches have plated-steel casings to resist corrosion. The 5-A 12-Vdc switches are available with two 12-in. wire leads with ring terminals and are sealed with a rubber boot for protection against dirt and moisture.
Cole Hersee Co., 20 Old Colony Ave., Boston, MA 02127, (617) 268-2100, colehersee.com
