Flange-reaction torque sensor
Sept. 13, 2007
Used to evaluate low-torque components and controls, flange-reaction torque sensors measure small-reaction torque levels using flange-to-flange connections in-line with the component under test.
The sensors use a hollow cruciform element structure for extraneous load-handling capabilities. Available torque ranges are 50 to 1,000 lb-in. (6 to 113 Nm).
Sensor Developments, 1050 W. Silver Bell Rd., Orion, MI 48359, (248) 391-3000, sendev.com
