The Radsok system is a patented electrical terminal based on a hyperbolicgrid configuration. The cylinders have elongated contactor strips connected in spaced, parallel relationships, twisted into a hyperbolic shape. The hyperbolic configuration ensures a large coaxial, face-to-face engagement area for a low millivolt drop connection with low insertion cycles and off-axis insertions.
The Tru-Lok connectors have a molded-thermoplastic main plug body and secondary latch, with Viton main and wire seals. They work in harsh environments, such as under valve covers, on diesel engines, and other underhood-interconnect applications.
Amphenol Industrial Operations,
40-60 Delaware Ave., Sidney, NY 13838,
(607) 563-5011, www.amphenolindustrial.com
