These servoamplifiers target closed or open-loop velocity and torque control of BLDC motors producing more than 160 oz-in. at 7,000 rpm. Input voltage varies from 10 to 50 V with a rating of 20-A continuous and peak of 40 A. Weight is 0.44 lb. Other features include quick-disconnect for wiring, onboard LED status indication, enable, FWD/REV, and tachometer output. Amplifiers are protected from overcurrent, short-circuit overtemperature, voltage, and loss of feedback.
Servo Magnetics Inc., 6660 Variel Ave., Canoga Park, CA 91303, (800) 457-3786, servomag.com
