Optosensors Mount in a Snap
Oct. 21, 2004
The MS Series miniSnap optosensors mount quickly by snapping into a hole which directly connects it to the control unit.
Optimized beams eliminate the need for alignment and adjustment of the emitter and receiver. The sensor's 19.3-mm-long housing, made from high-grade polyamide 12, encapsulates and protects electronics from dirt and water. Two side wings provide a tight and secure fit in plate thicknesses from 1 to 6 mm. An intelligent, active disturbing light suppression makes the sensors extremely insensitive to foreign light and other interference sources.
Jaxxen Inc., 4 Byington Place, Norwalk, CT 06850, (203) 838-6200, jaxxeninc.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
