Embedded Thermoelectric Cooler
July 26, 2007
Made from nanostructured thin film, the eTEC cooler works as a miniature, solid-state pump to cool hot spots on ICs.
Made from nanostructured thin film, the eTEC cooler works as a miniature, solid-state pump to cool hot spots on ICs. The device pumps as much as 400 W/cm2, as compared to less than 10 to 20 W/cm2 for typical bulk TECs. eTECs measure a few millimeters per side and are 100 to 400-micron thick.
Nextreme, 3040 Cornwallis Rd., Box 13981, Research Triangle Park, NC 27709, (919) 990-8300, nextreme.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
