Stainless-Steel Linear Guide
April 26, 2007
A stainless-steel version of the DryLin W compact linear-guide system is suitable for harsh environments.
The guide is manufactured of solid 316 stainless steel and can withstand temperatures to 482°F. The stainless-steel carriage includes plastic glide elements made of iglide J. For higher temperature resistance, the plastic liners can be made from iglide T500 for the 20-mm size. The unit is available as a combination of two supported round shafts in one bolt-on profile or as a split-rail configuration.
igus Inc.,
Box 14349, East Providence, RI 02914,
(800) 521-2747,
igus.com
