Thin-film adhesive
Sept. 1, 2005
CV-2680-12 is a reinforced, static-dissipative film adhesive designed for ease of use in bonding and fastening applications.
It can be customized as standard, optically clear, and electrically and thermally conductive sheets. The film comes in 12 12-in. sheets and is reinforced with a fiberglass scrim. Users can die cut the sheets and the adhesive's low-flow characteristics eliminate overflow and clean-up issues. The material has a press/cure time of 4 hr at 65°C
NuSil Technology LLC, 1050 Cindy Lane, Carpinteria, CA 93013, (805) 684-8780, nusil.com
