New Product: Enclosure
Nov. 8, 2007
The BOS-Ecoline enclosure system is for use where custom sizing is required.
The clear anodizedaluminium profiles are available in three versions: closed, open on one side, or split profiles — in four sizes from 57.5 to 120 mm. The profiles come with integral guide grooves for PC boards and feature recessed areas for front membranes or membrane keypads. Two ABS plastic end caps, with or without wall brackets, are available.
Rose+Bopla Enclosures, 7330 Executive Way, Frederick, MD 21704, (301) 696-9800, www.rose-bopla.com
