Metering Valves
March 9, 2006
Dyla-Trol valves provide precise metering for control of cylinder motion.
The in-line flow controls combine smooth laminar flow with precise adjustment. The components offer fast resetting and repeatability with each cycle, letting users fine-tune cylinder speed. The compact in-line design simplifies flow setting and plumbing, and is suited for use wherever air or oil flow must be controlled.
Mead Fluid Dynamics, 4114 N. Knox Ave., Chicago, IL 60641, (773) 685-6800, mead-usa.com
