Chute Lube , a specially formulated blend of silicones, cross-linkers, and oils, is designed for package-handling and food-processing equipment, chutes, guides, and rail conveyors. The lubricant comes in 20-oz aerosol cans that deliver a spray powerful enough for difficult-to-reach areas. The long lasting coating will not stain or cause packages to become greasy. It is also colorless, odorless, and is harmless to most rubbers and plastics. Chute Lube is effective in a wide range of temperatures and is NSF H2 registered for use in meat and poultry plants.
CRC Industries, Industrial Products Div., 885 Louis Dr., Warminster, PA 18974, (800) 272-4620, crcindustries.com
Safety Products Overview
Dec. 20, 2024
