The high-capacity G5LA-E relays have a resistive load rating of 5 A at 250 Vac or 24 Vdc on the NC contacts. The units operate over an ambient temperature range of 40 to 85°C and are available with Class F coil insulation (G5LA-CF).
Each relay measures 19.6 15.6 15.6 mm creating a lower profile than existing packages while still maintaining the industry standard footprint. The G5LA relay conforms to VDE0435, UL508, and CSA 22.2 standards. Nominal coil power consumption is 360 mW for the 5, 9, 12 and 24-Vdc coils and 480 mW for the 48-Vdc coil. All models are RoHS compliant.
Omron Electronic Components, 55 Commerce Dr., Schaumburg, IL 60173, (847) 882-2033, components. omron.com
