The unit's digital temperature control ranges from 104 to 410°F for polyurethanes (PU) and thermoset hot-melt cartridges. The 3.3-lb applicator runs off 600 W, with operating pressures between 29 and 82 psi. It is suited for one-part moisture-curing PU adhesives that bond wood, plastics, rubber, and plasticized vinyls. The 700K model is also available in spray and extrusion models.
PAM Fastening Technology, 2120 Gateway Blvd., Charlotte, NC 28208, (704) 394-3141, pamfast.com
Safety Products Overview
Dec. 20, 2024
