Epoxy-Based Push-Mount Cable-Tie Assembly
Push-mount cable-tie assemblies are tamperproof and have a low profile to prevent snagging when the cable is trimmed and the harness is pulled through a bulkhead.
July 13, 2006
The remaining terminal end falls below the low-profile receptacle, eliminating sharp edges common in most wire ties. Push-mount wire ties snap quickly into a panel sheet with a maximum thickness of 0.135 in.
Device Technologies Inc., 155 Northboro Rd., Unit 8, Southborough, MA 01772, (800) 669-9682, devicetec.com
