Linear Potentiometer Family
Sept. 27, 2007
The CLP, CLWG, and MLP family of linear potentiometers are said to operate 25 to 50 million cycles at speeds over 400 ips at a frequency ceiling of 50 Hz.
Measurement range runs from 0.5 to 30 in. Rod diameters vary from 0.2 to 0.4 in., while the high-strength rod-end connection points let the units mount with basic pin fasteners. Up to 0.04% linearity is attainable with repeatability errors of <0.01 mm. Operating temperatures range from –22 to 300°F.
Celesco Transducer Products Inc., 20630 Plummer St., Chatsworth, CA 91311, (800) 423-5483, celesco.com
Dec. 23, 2024
Dec. 23, 2024
Dec. 23, 2024
Dec. 20, 2024
