Miniature Solenoids
Sept. 16, 2004
The C5 Series miniature open-frame linear solenoids are approximately 20 x 10 x 12 mm.
Available configurations include magnetic latching rated for forces up to 3 lb, or a standard on/off version rated for use with forces in excess of 3.5 lb. Small size and low power consumption let the C5 work well in battery-operated applications. The magneticlatching version is designed for very-low dutycycle applications where the solenoid needs to remain in the energized position for extended periods of time.
Saia-Burgess Inc.,
801 Scholz Dr., Box 427, Vandalia, OH 45377,
(937) 454-2345, www.ledex.com
Dec. 20, 2024
Safety Products Overview
Dec. 20, 2024
Dec. 20, 2024
Dec. 20, 2024
