Distributed Pneumatic I/O
June 3, 2004
The new FD67 distributed I/O system is suitable for use in Fieldbus systems such as DeviceNet and Profibus.
DISTRIBUTED PNEUMATIC I/O
The FD67 features comprehensive debugging with single-channel diagnosis and shut down. Fully encapsulated electronics and an IP67 rating let the system withstand washdown environments, shock, and vibration. Multifunctional I/Os means no separate input and output modules, reducing system costs. The machine is completely independent from the controls and fieldbus. If end users require a different fieldbus, the machine builder need only change the bus coupler; the I/O periphery needs no modification.
IMI Norgren Inc.,
5400 S. Delaware St., Littleton, CO 80120,
(303) 794-2611,
www.norgren.com
