Rigid Shaft Coupling
Feb. 9, 2006
Accu-Clamp couplings have an axial runout of less than 0.001 total indicated run-out.
The one-piece coupling incorporates integrally machined selfcentering collars at both ends, eliminates conventional longitudinal slot, and provides close tolerance bore and keyway. The coupling is suited for line-shaft applications and instruments needing high-precision shaft alignment.
Stafford Manufacturing Corp., Box 277, North Reading, MA 01864, (800) 695-5551, staffordmfg.com
