The system is comparable to traditional Seal-Lok (SAE J1453) products, and also adapts to a line of light-duty, flexible, corrugated stainless-steel tube traditionally used in the gas-appliance industry. The compact design features shorter threads on the ORFS end, while fittings with SAE-ORB studs feature a light-duty port stud with shorter thread length. Fittings are also available with light-duty male NPT threads. Seal-Lok Lite assembles with existing Parflange tooling and equipment.
Parker Hannifin Tube Fittings Div., 3885 Gateway Blvd., Columbus, OH 43228, (614) 324-8227, parker.com
Jan. 10, 2025
Jan. 10, 2025
