New Product: Embedded computer boards
May 8, 2008
The low-power-consuming conga-CA embedded computer boards feature Intel Atom processor Z500 Series and Intel System Controller Hub US15W.
The conga-CA supports up to two PCI Express Lanes, eight USB 2.0, two Serial ATA, one IDE Interface, and Intel High Definition Audio. It also features a PCI bus, multimaster I″C bus, LPC bus, fan control, and Gigabit Ethernet.
Two different CPU variants are available. The conga-CA eco version is powered by the Intel Atom Z510 processor with 1.1 GHz and 400-MHz front-side and memory bus. The high-end version is powered by the 1.6-GHz Intel Atom Z530 processor with 533-MHz front-side and memory bus. Both versions are equipped with 512k L2 cache and can access up to 1 Gbyte onboard DDR2 memory. The modules come with an embedded BIOS and board controller to enhance features such as system monitoring, watchdog timer, and the I″C bus.
congatec AG, Auwiesenstrasse 5, 94469 Deggendorf, Germany, +49 (991) 2700-0, congatec.com
