Liquid-Level Sensors
Sept. 27, 2007
New catalog covers the M-Series products with Temponsonics magnetostrictive technology, as well as diagnostic, programming, and accessory options.
The surface-mounted MG digital sensor includes automatic data-error checking and is used for 508 to 12,192-mm vessels. The modular MR analog output sensor offers various electronics housing styles, sensor-pipe styles, and construction materials. M-Series sensors feature a removable sensing element so the element and housing can come out of the pipe without interfering with operations. Two 4-to-20-mA loops for analog indication of level, interface, and temperature lets the sensor indicate and display two measurement variables simultaneously. Also covered is the M-Series MC420 analog output sensor,.
MTS Systems Corp., Sensors Div., 3100 Sheldon Dr., Cary, NC 27513, (919) 677-0100, mtssensors.com\
