Pocket & Bayonet Slides
A pocket and bayonet-mounting method reduces the time needed to install the slide and drawers into a vehicle body. A latch at the front of the slide activates lock-in and lock-out action to keep drawers safely open for access or securely closed for transit. The frontrelease latch mechanism resists disengaging when subjected to side-toside racking, vibration, or impact. The highly visible latch is coated in a durable yellow plastic. The slide may be paired with Model 9322, a nonlocking companion slide, for applications requiring one-side locking only.
The slide has full extension, a 300-lb load rating, 0.75-in. side space, and comes in 10-36, 40, 42, 48, and 60-in lengths with a clear-zinc finish.
Accuride International Inc., 12311 Shoemaker Ave., Santa Fe Springs, CA 90670, (562) 903-0200, accuride.com
