Designed for purpose-built or converted light-duty vehicles, the wheel end brake is an alternative to standard OEM brake systems that require constant maintenance in harsh or corrosive environments. The wet, multiple-disc brakes are completely enclosed and replace standard caliper-disc and drum brakes. The brakes feature a spring-applied, hydraulic release for parking/emergency braking at each wheel. This feature has a maximum static torque rating of 40,000 lb-in. at 0 psi, while the service brake has a maximum dynamic torque rating of 30,000 lb-in. at 1,500 psi. The brake has an initial release pressure of 500 psi and full pressure release of 600 psi at maximum torque. The brake's spring-applied section requires 1.0 to 2.0 in.3 of oil, and its servicebrake section requires 0.23 to 0.46 in.3 Common hydraulic fluid is used for actuation and cooling.
Mico Inc., 1911 Lee Blvd., North Mankato, MN 56003, (507) 625-6426, mico.com
