Hygienic Grippers
Feb. 8, 2007
The 2-Finger Angular Gripper Type LMG 64 is designed to Hygienic Design requirements of the food-handling industry.
The 2-Finger Angular Gripper Type LMG 64 is designed to Hygienic Design requirements of the food-handling industry. Built from high-quality stainless steel, the gripper housing is corrosion resistant and easy to clean. The gripper's completely seated mechanics make it suitable for use in extreme working conditions and its lubricants comply to food-industry standards. The LMG is equipped with an integrated spring that maintains gripping force in case of air loss. Proximity switches, located in the gripper housing, monitor end position. Operating pressure is between 4.5 to 6.5 bar for a gripping force of 520 N.
Schunk Inc.,
211 Kitty Hawk Dr., Morrisville, NC 27560,
(800) 772-4865,
us.schunk.com
