The A-Track Series linear actuators incorporate new design features, including a round, ground ball nut, a motor shaft supported by bearings instead of bushings, and limit switch and potentiometer options.
Four models are available for a wide variety of applications. The actuators can move loads from 25 to 1,330 lb. Units come prelubricated and need no maintenance or adjustments.
Warner Electric, 449 Gardner St., South Beloit, IL 61080, (800) 234-3369, warnerelectric.com
