A StepLogic function lets the drive work as an independent position controller for simple time, digital-input, or communications-based indexpositioning applications, eliminating the need for a separate position controller. The unit features an optional DriveGuard safety relay that lets users shut down a section of an application for maintenance, while keeping the remaining sections running without removing power to the drive and I/O. A drive-plate version is available that reduces the cabinet size by allowing the drive to be mounted to an external heat sink. The drive is available in power ratings from 0.4 to 11 kW and in voltages of 240, 480, and 600 V.
Rockwell Automation, Response Center, 10701 Hampshire Ave. S, Bloomington, MN 55438, (800) 223-5354, rockwellautomation.com
