The eight-roller pumps have flows up to 24 gpm and handle fluid temperatures to 140°F. Shafts of 416 stainless steel with heavy-duty sealed bearings supporting both ends have extra-fine finishes to minimize seal wear. Close tolerance machining on the corrosion-resistant rotors assures maximum flow and pressure, and prolongs roller life. Available options include PTO adapters and reverse rotation. Standard rotation is counterclockwise, with clockwise optional.
Delavan Ag Pumps Inc.,
1228 Chestnut Ave., Minneapolis, MN 55403,
(866) 335-2826,
delavanagpumps.com
Aug. 29, 2024
Aug. 28, 2024
